Operate Windows From Key Fob
just a quick one for you
i had a 2002 mk1 ls which when you held the lock button on the key fob for about 3 seconds would close the windows and "moon" roof, or if you did the same with the unlock button would open them all.
i now have a 2004 mk2 ls and it doesnt have this feature. is this a dealer only reset, or is this feature not on mk2s at all, or is it one of those times when i have to put ignition switch to acc, open the door 3 times, shut the bonnet, press ac twice, and rub my stomach and pat my head at the same time?
thanks for your help, i know someone will have the answer
andy
