How Good Are These
ian h
Yep... 1) You almost never if ever have to change it out, so reduced service costs. 2) You get more air flow through the K&N filter which gives a cleaner fuel burn and can add a wee bit to fuel efficiency and smooth running.
Col
it has to be removed for cleaning and re-oiling,
your other points are pretty subjective, without proof, the oem filters are very good, being of Exactly the same construction as the TRD air filter, .....but not red
You'll save money in the long run with a K&N. They also flow better longer than an OE unit. They might be very similar when new but after 15K the K&N wont be as restrictive thus improving your mpg. If you can get one cheap enough then go for it I say.
