Altezza
wesleym00
You'll need something like a HKS or Greddy speed cut defender. You should be able to pic one up from your local importer/retailer or else there's plenty of online shops that will send direct from Japan like RHD, JPS & Nengun.
If it's just a seal kit you need for the pump then you could most probably source one through you local dealer http://www.toyodiy.com/parts/p_J_199904_TOYOTA_ALTEZZA_SXE10-AEFVF_4502.2.html?hl=04446
Any P/S specialist ot mechanic should be able to do the job for you from there.
