Trd Sportivo Suspension Kit
greycobba
...was thinking about the Teins.
Which Type? (I use the Type Flex; the dampers work OK, but the springs are far too soft to be used on track)
I do not think the springs are soft. Probably you have set your coilovers to be soft. Teins Flex are the optimum coilovers and usually are stiff. It has also the advantage that the ride height does not affect the springs.
