Rear Suspension Diagrams
Anyone have a link to or have diagrams of the rear suspension so I can identify which bush I need to replace, its the arm on the nearside and goes from the front to the inside of the hub but in order to get the right bush I need to know the definition (name) basically.
Another problem I have is after changing the cigar lighter in the centre dashboard im not getting any power to the new one, at the same time I removed a nokia phone system ?
If it is the square shaped arm which connects to the drop link to the anti roll bar it is called the "Arm Assy Rear Suspension # 2" part # 48730-50010 and the bush is # 48725-50030.
If this doesn't sound right and you can take a picture I will help further.
I found this which number is it?
http://www.clublexus.com/forums/attachments/ls400/159807d1261295254-help-with-vibration-92-ls400-ls400-rear-suspension.gif
The whole assembly is called the 'Rod assy,strut rear" part # 48780-50010 cost in Euros is 99.00 the actual bush is part # 48725-22110 around 19.00 Euros.
PM ACLex who may offer a discount and postal delivery.
Great found the parts on the diagrams but cant find listing for bush in the
CARRIER SUB-ASSY, REAR AXLE, LH
**305-500101989.05-1994.10this is what the 'Rod assy,strut rear" part # 48780-50010 connects to, just have to avoid the potholes for a while longer :lol:
The rear lower axle carrier bush is not available from Lexus, just the whole unit
I got mine from the USA, poly pushes called ADUS.
If you type bushes, bushings, bush into eBay someone is selling them at about £45.
Try also 'Polybush'
Try also 'Polybush'
Phoned Andy at Lexus and got two bushes to cover both sides and then found the superflex bushes to replace the bush on the hub and bought a new heavy duty Battery to see her through winter B)
Try also 'Polybush'
Sorted
