220D Noise When Changing Gear
I am looking at getting a 2006 (56) IS 220d and whilst on the test drive noticed that when changing gear there was an audible "clunk". It wasn't loud and didn't sound too bad but I was just curious if this was a normal sound or something that should be checked out?
Many thanks,
  • 1 month later...
Same thing on mine.
It's early DMF failure, but your dealer won't admit it. Instead they will take you out on a test drive and drive with really slow and deliberate gear change actions and tell you nothing is wrong. It's caused by having 40mph/1000rpm in 6th, so you are straining the DMF when you drive it like every other diesel - top gear @ 70mph an not @85mph like it says in the manual. Basically 6th is almost useless in the UK
