Finally Modded The Car :d
LOcKY
Hi Peeps!
Finally got the TTE front bumper, brembo brake discs, BC RC coilovers and lowered by 20mm today :)) I'll try and get some pictures up, but its too dark now and the horrible snow means its staying on the driveway till the white crap disappears :)
I'll post pictures tomorrow when i can.
I like to thank breet (TTE front bumper fibreglass edition), Sheeldzy (BC Racing coilovers) and SINGH182 for the brembo brake discs :)
Colin
Pictures Coming to a screen near you!
Update! as promised here are the pictures :)
dscn1380edit.th.jpg dscn1382edit.th.jpgdscn1383edit.th.jpgdscn1381edit.th.jpg
Yup its a replica, however the person i bought it off said it was a genuine so you could say i only found out when i took it to the body shop to be told it wasn't actually genuine :(( it looks good from the limited time i saw of it as it was really dark, but i was surprised how good it looks.
Also i was thinking of popping the Lexus badge back on, however the de-badged version looks kinda cool :P
Colin
it was me that removed and fitted daves bumper. remove the clips and star screw from under the bonnet pull the splash guards back slightly you will find a 10mm bolt each side approx 5 10mm bolts under the bumper then pull it off if you have head light washers pull the pipe off on the n/s
rear bumper a few 10mm bolts and a few clips and pull it off...
you have to remove some of the boot trim...theirs 4 10mm nuts behind the boot trim..theirs poss 10mm bolt either side of the rear bumper plastic clip either side and two plastic clips at the rear..
