Injectors
TRD328
Hey does anyone know the size of the injectors on the is200?
need name, model # and size. Or the spec for a slightly bigger injector that is suitable to the IS200?
Need to get bigger injectors for my baby.. coz 10psi max i can run on stock injectors.
Had the car up to 157kw rear wheels today :P
157 rw....... wicked!
Where did you source your turbs kit from?(gettin the bug for more hp) ;)
sorry,not famliar with injector sizes-have you thought about water/methanol injection to cool the intake charge= more boost? or there is always Tuolene injection.....
the "turb" kit was from AVO in melbourne www.avoturbo.com.au
I can go up to 14psi but it'll be running too lean with the current injectors, so putting it back down to 10psi.
The car had problems getting traction on the dyno coz of the car having too much negative camber on the rear (too low, and no Mat, not 300mm drop), but it was stil lgoing strong on 14psi and should be able to extract a bit more from there.
  • 5 months later...
