Welded Diff
SGTFUZZ
Hi all got a 1991 ls400 there was a gearbox problem so i go it fixed but i dont want to drive as it has a welded diff i have had a car with a welded diff befor thats no problem but the ls400 is a auto will it blow the gearbox :shutit:
I can't see what difference being automatic would make. If a welded diff could blow an auto, it could blow a manual.
I can understand your reluctance. Do you have any history of the repair? If its just been done and you don't know why/trust it then I would get a replacement. If it was done 10's of 000's of miles ago then its likely to be fine.
No doubt Benfur (a fellow LOC member) would have a replacement and Simon Taylor has a breaker at present. PM them.
Hi i dont know nothing on this car :blink: all i know is i piad £200 to get the box replaced :winky: dont know who weld the diff or how the gearbox went the car has 12000 on the clock the thing im asking will it be ok for a month or so till i get a diff
thanks
thanks
Fair enough. In that case I would check the oil level and then try the car, stereo off, all windows down and listen and feel. Any noises from the transmission or jerks in the drive and I WOULD lay it up until another diff can be fitted. If all seems good, treat it gently.
thanks
and avoid sharp corners or your tyres will be history pretty quickly. :hehe:
