Oil Change
VoipX1
Hi i am about to change the oil on a Lexus GS300 1996
I have a filter, and oil.
Do I just un do the drain plug. drain,
take filter off
replace filter and fill ?
I gave the garage new washer for the drain plug last time, do I need to change it this time ?
Yes as easy as that. They hold about 5 1/2 litres and do use a new sump plug washer.
Thanks,
Done,
I noticed the oli needed changing when the engin would not start properly, about 4 times I tried to satrt and it woul;d not.
I thought it was the Battery, then the starter motor but it turned out it was low oil.
The first turn of the key would do very little (but I guess forced oil where it needed to go)
The engin just did not turn over at all, not even much of a rotation once…
after that it would start fine…
My worry is how much damage did that (or could that ) do ?
