Sat Nav Dvd Player
Hi all,
Anyone out therer know if an IS200 boot mounted satnav player will direct fit into my 2002 300 Sportcross?
As long as it's a DVD unit I believe it should work fine but hopefully someone more technical can confirm :)
Hi all,
hi,does yours have a sat nav and a boot player?if yes chances are it will as long as its the same generation sat nav as yours - the earlier ones were cd rom while the later ones are DVD.
Thanks for replies, yep satnav already but the boot unit is u/s.....good point about cd or DVD, I reckon mines DVD will check. The cars 'original' at the moment and I want to keep it that way if poss rather than going down the Ormi/Sony/headunit route!!
Hi,if thats the case then I would say as long as you get a DVD one,it should hopefully just plug in and away you go.
