3 Electric Windows Not Working Since Battery Change
2 hours ago, rich1068 said:
Everyone else is joining in this 9 year old thread. I was feeling left out.
So, window experts. Different car ('02 GS) but my passenger window just will not go back up on it's own from the control on the driver's side. I've tried holding on down, holding on up, half way down, everything. Just refuses to work. Works fine from the passenger side switch. Any ideas?
My is200 dont have to be recalibrated after Battery cut. So older Lexus maybe dont have this problem (solution).
4 hours ago, scudney said:
Probably a problem with the drivers master control switch especially if the passenger side switch works ok🤔
Definitely a problem with the master switch unit - or the wiring to it. Try disconnecting/reconnecting the wiring to the switch unit, this has been known to fit this issue.
Cheers Colin. But unfortunately I've had the block connection off numerous times when I've removed the door cards for the speakers and I can't say it's ever made any difference.
It's only a little thing. This thread just reminded me of it.
