Mk3 Boot Remote Doesn't Work !
hi
Check that it isnt locked - if the round silver barrel is pushed in (under right handside of steering) then it is locked and wont open - you need to unlock it with they the master key.
It will also not open if the engine is running
HTH
miq
Thank you, that was easy then !
The silver barrel lock was closed, never touched that before in any of my 3 x LS400's
Works a treat.
Thank you.
