Driveline Noises
WillBC
Hi All,
Got a couple of 'new noises' on my IS200 which i'm pretty sure shouldn't be there. Hoping some of you may have heard them before and know what causes them.
MP3 here -> http://www.filedropper.com/engine-noise
- First is the high pitched one at idle, this seems to be coming from the ancillary belt region, but only occurs at idle.
- Second one is at 8 and 12 seconds in the clip, a quite loud 'wobbing' noise that occurs around 1000rpm (so it goes once the engine reaches slow idle), that's always there and comes from deep in the bowels of the engine!
I've ruled out gearbox as the same noises occur in neutral with the clutch in and out.
Any suggestions?
Will
