Sign in to follow this
nottonto
Question About 220 D Engine
Hi
there's a small black plastic component on the top of my engine above the turbo, it looks like some kind of pump as it has two small diameter rubber pipes onto it, one on a fitting marked "out" and one on "vac", I presume it's a vacuum pump for something, there's quite a few small diameter pipes leading about the engine, the reason I'm asking is that recently I have noticed it running when I come to a stop with the engine running, I've only recently noticed it so I'm worried something is happening that shouldn't be.
could anyone please enlighten me?
thanks in anticipation nottonto
Inspect the VRV for an open circuit.
Using an ohmmeter, measure the resistance between the terminals.
Resistance:
11.1 to 12.5 Ω at 20°C (68°F)
Inspect VRV operation.
Check that air flows from port E to G.
Apply Battery voltage across the terminals.
Check that air flows from port E to the filter.
Resistance:
Apply battery voltage across the terminals.
Hi Fonserg
thanks for the info., but what is the item, is it supposed to be running and what's it for ?
Is it causing any more damage if I don't get it sorted?
thanks again nottonto
Resistance:
Hi Fonserg
It could be the EGR vacuum modulator but to be sure send a PM to LOC member Ormi and he will know for sure.
VRV Vacuum Reducer Valve
Found this on a search
http://www.lexusownersclub.co.uk/forum/index.php?showtopic=74386
As I have understood from the engine scheme it is the valve of management of turbine geometry. If it doesn't work the engine loses all capacity.
Hi guys
thanks for your help, I've viewed the other post and it seems I should get it looked-at.
I tried to PM Ormi but got a message saying he could not use the system?
My car is two months out of warranty and only done 30k, thought it would be bullet-proof for 3 yrs :crybaby:
nottonto
Hi everyone/anyone
I've just phoned Lexus Leeds and they say there's nothing to be worried about, the pump only runs sometimes, if there was a problem with it there would be a warning light on the dash.
happy days, thanks for your help
nottonto
Agree with Fonserg. This is the valve swichting regulator, and works in the variable geometry circuit of turbine Compressor.
