Engine Swap
Deafluggs
Hi everyone.
I've just bought an engine & gearbox (manual) with only 33,000 on it.
My question is,are the Ecu's "plug n play" as it's exactly the same unit going in as the one coming out, if not will i need the ecu from the donor engine ??????
Thanks.
Hi everyone.
Thanks.
Hi im 95% sure they are plug n play as long as you unplug everything from engine bay and plug back to new engine as if you change ECU you will have to change key's and lucks. If im wrong anyone?
  • 2 months later...
