Which Lead Do I Need To Fit An Aftermarket Cd Player?
Khany91
I have a lexus is200 sport and i tried fitting an aftermarket normal cd player in but the wires in the back dont connect ? can anbody help at all?
which wire or adapter do i need ? or is there any other way ?
THANKS
You need a amlifier bypass cable easiest is on eBay.
you have to disconnect the lead coming from the amp which is found left hand side behind the glovebox then connect the new lead run it behind the glovebox and connect to the back of after market stereo job done.
