Fog Lights Front
gds
Your local dealer may not stock it but they can order you one ??
I got my last pair through:Name: Inchcape Nottingham
Address: 406 Derby Road
Nottingham
Nottinghamshire
NG7 2GQ
Tel: 0115 942 1700
Fax: 0115 942 4489
Website:
www.toyota.co.uk/inchcape-nottingham
EMail: im@inchcape-nottingham.toyota.co.uk
who were kind enough to offer a discount when prompted for one
They will only deliever to a 'business' address as far as Im aware though - give em a try
:mat:
I cant recall as mine were being replaced under a warranty deal with garage. I think they may have been £125 each but I found Inchcape very helpful. Had to ring them to see if the garage were telling me porkies about delivery etc (long story)
:crybaby:
bluebeard and grim, many thanks for your input, will try your part number with the local toyota dealer, however the fogs on the altezza are not the same as is200 lexus, cheers, gds
Was the £125 for the whole light? Is the lens available separatly on the IS? On the GS you can just get the lens for about £50.
The part no. I have given you should be the round type as used on the Altezza.
As in this piccy...
Yes, I know the above piccy ain't a Tezz, but the fogs are the same...
gds
I have the same fogs - the part number above is correct for the clear fogs or you can get 08590-53020 for the multi-colour blue/yellow versions as on my car.
However I was investigating these a while back too, and they aren't cheap - mine are cracked from stones and i wanted to replace them. I didn't see the point in getting a new set for them just to crack again, so I'm just going to put some translucent vinyl 'covers' on them.
Asam
