High Idle Speed When Cold?
Daniel N
I've tried searching the forum but couldn't get an answer to my problem :-(
My IS200 1999 Sport, idles at 2000 RPM when cold! When it's warmed up there's nothing wrong, it idles at 600-700 RPM. No fault codes and TPS is adjusted corectly. Throttle body is also clean.
Does anyone have the same problem or maybe someone knows what is causing this?
Daniel
