Is 250 - Parking Assist ?
Got my 06 Lexus IS 250 (is perfect !) came with the multimedia pack mark levinson etc, reverse camera but how do I find out if it has parking assist sensors... If so how do I activate them? The manual says refer to the separate navigation manual which I haven't received, on the back and front I have those square blocks so assuming they are the sensors.
Thank you.
Thank you.
Not sure what you mean by 'square blocks'. That sounds like you are referring to the two covers to the towing eye positions (you have a tow eye in your toolkit). The parking sensors are round and there are four of them (see pic of the rear). One either side of centre and one on each corner. There's only two on the front, one at each corner.
Activation is normally set to ON but can be set OFF by the PDC knurled control on the right hand side of your lower dash behind your steering wheel.Scroll through the options & set to ON & you will see a GREEN light come on in your Instrument Panel----hope this helps!
Tel
  • 2 months later...
