Warning Lights On !
Yamavira
08 250IS auto.
Set off from set of traffic light as normal. Main warning light came on (no sound), message in top window "Check VSC". Also illuminated, in lhs of panel the Little engine symbol (Indicates TRC/VSC fault) illuminated & in the RHS panel "Slip indicator" light is illuminated.
Would welcome any thoughts, comments as likely or probable problem.
Yamavira.
