Headlight Washers On S Model
wicked677
I have the S model that does not include headlight washers, does anybody know if it is easy to install headlight washers? I saw some guys red IS200 with the windscreen washer caps, they were really small and unsighty compared to the originals. Would be good to see if the tubes are there ready?
From what I've read and understood on these forums, is that with Lexus' unless your car came with it fitted, then the stuff you need to connect up to simply isn't there, and retrofitting is a bitch as a result.
all you need to do is swap over your washer tank with one with washer, for the pluming to washer jets. scrapers have them for 30-50 quid, similar to this. The lower pipe goes to washer jets.
(ignore illustrations, had a leak!, but saved this pic)
Personally, I wouldn't bother. You'll never use them. I've used mine probably twice, and both those times were to demo them when I first got the car. The novelty soon wears off
