hi there, after a recent heavy rainfall i noticed some water running down the end of the dash when i opened the passenger door, it had been dripping off into the footwell giving me a wet carpet. the door seals look intact and i cant figure out where its getting in. has anybody else come across this and found where it was getting in, i'm guessing windscreen seal but there's nothing to see ??
My first guess would be sun roof, a very common area for leaks. Have you checked your drain holes?
Phil
thanks for the reply, i'll check them when i get chance and let you know. Mike.
Just so that you know how bad it can be if the drain holes are blocked, mine was flooded in one evening to the point where it set the alarm off!
