Stere Wiring Help!
Please help!!!
I have just bought my first Lexus (1999 IS200 sport).
She is in mint condition, everything is wonderful, the only thing is the last owner changed the headunit for an aftermarket one, I bought the car with the original stereo fitted in place but not connected, "all you need to do is slide out the stereo and plug the multi plug in i think" I removed the stereo and to my horror discovered that the plug was butchered so close i cant easily see which wires goin which plug and and at what pin!!!
Please can someone advise me where all the wires go in the plug and better still could someone with an identical car send me a picture of the fully wired plugs so that i can get out the soldering iron and fix it up, I have managed to connect it all to a fashion, radio and mirrors are working as is the illumination but, the CD player isnt and it would seem it is drain the Battery like near is so tomorrow. Please please please help me.
Thanks IanS200!!
Dont suppose you have a picture of the plug as well by any chance? turns out i'm not so good at reading the wiring diagram as I thought it was!!!
Ok not to worry.
The biggest issue I have is there is a small blue and yellow wiring thats in the bunch that goes to the big block, i have i think found homes in the block for all the other wire except this one, the end of the wire is striped but, i can't for the life of me see where it has to connect.!!!
That should be permanent live according to wiring diagram, goes to pin 1 on big block. that will be top right of plug looking at it from wire side with tab of plug at top
