hi, can someone tell me where can i find a breather hose from the plenum chamber or the manifold or the vacuum servo hose from the brake servo in a 98 MK2 Gs300??
i want to fit a ECOTEK into my GS300, anyone had any experience with them?
Don't know if this is what you are looking for. If you remove the black cap (labelled on the attached photo), you will find a source of vacuum that goes directly into part of the inlet manifold.
Please don't blame me if you cause some damage to your motor by fitting one of these Ecotek things. Quite frankly, the idea of attaching anything to the brake booster vacuum sounds nuts. At the very least it could reduce braking power. Anyways, I don't think (correct me if I'm incorrect) that the GS300 has a vacuum assisted brake servo-I think it's electrically pumped.
Hope this helps
