Hi Ryan. I did sort it in the end. After fitting new plugs and a new set of coils which did not sort the problem I checked the injectors, you can easily check these, when the engine is missing, by carefully unplugging them one at a time. The misfire will get a lot worse when unplugging the good ones but will stay the same if you find the faulty one. You can also check them with a multimeter with the engine stopped. I bought a second hand one on eBay for £25 spot on. Hope this is of interest to you. Cheers.
