Guys,
I came across this thing in the sat nav manual, what is this? it says when in auto mode hold down the recirculate button and a smog screen will appear? has anyone tried this?
out of curiosity more than anything!
for the auto recirculation feature there is a sensitivity setting. You hold down the button to access it. Obviously the more sensitive the setting the more often the system will go into recirculation mode. On my old GS I found the default middle setting was about right.
I don't have the screen on my 2005 model (or if I do, I don't know how to activate it), but the smog sensor sensitivity can be programmed using a laptop and a techstream cable.
The way I got it to work was:
Press auto button on left, so that system is in auto mode.
Press recirc button until auto recirc/fresh light is on. The hold recirc button for 5 seconds.
duh
so, i realised i dont have an auto mode
https://www.dropbox.com/s/ywnooe9kq5d5l08/20140711_174724.jpg
this is the replacement sat navi bought a while back
and yes, its from a diesel.
My original (broken) unit has the auto bit,
now, whether or not i got the bAll$$$ to rip open my lexus AGAIN to replace this part of the sat nav is another thing, and i am not sure if it will work.
at the moment it works fine, of course being who i am, i would like it functional the way it should.
I took this off my original sat nav, IF I put this onto the diesel replacement that i got now i wonder would this smog sensor auto function work? also it would remove all traces of diesel elements from my car :P
It should work but no harm to check opinions of others.
the diesel nav could also screw up that intrusion sensor....
https://www.dropbox.com/s/fep3q52i0c3dzpi/20140711_182846.jpg
my car is a petrol se-l, the 'button' is not there as i put on a diesel sat nav (which doesnt have this function as you know)., so i think the function should come back but taking out that sat nav is.....
nightmware.......
i took out the smog sensor and cleaned it,
https://www.dropbox.com/s/yxphpied5e7dagb/20140719_134129.jpg
it works really good, a trip down the coast here and it was all in outside air, once you drive up behind a diesel, doesn't take long to switch to recirculate, where it stays for most of city driving.
neat
