Rx450H F Sport 22" Wheels
Hi Guys,
Has anyone on here fitted 22" Alloys to a RX450H.
I am after seeing some pictures. Idealy wolfrace.
Pretty silly thing to do on an F Sport. 3 inches is drastically going to affect the ride and will likely need lower profile tyres too. There will also be differences in the speedo and the actual speed and you may need lowering springs to lower the car back down to normal height after fitting them.
It will probably affect the turning circle too and of course, if you're getting bigger wheels, you need bigger brakes to prevent the brakes looking really small. Personally, I wouldnt go for wolfrace wheels either, they seem too cheap. Only way to go is either vossen, work or BBS
Hi, Thanks for the reply,
I put 22" Khans on both my Range Rover Vogue and my X6.
The lower profile hardly changed the ride, I noticed a difference but nothing
dramitic and the wheels are exactly the same finished diameter so if done correctly
it will not effect the speedo.I also went 20" on my SC430. The main change was
less role which I saw as a positive.
What it did on all cars was greatly improved the appearence.
I am about to buy an F Sport and having driven my wifes RX450H advance and
then loaned an Fsport for a couple days from a local dealer,the only visual thing
I dont like is the wheel size they look too small. This is obviously a personal choice.
I saw the wolfrace vermont on a porsche cayenne and they looked stunning. It is
something I am going to do just hoped someone had a few pics.
I will take pics when the change is done and report on it.
Thanks again for your input.
Thats fair enough, its your choice at the end of the day. The wheels are exactly the same size as your wife's Advance though. Im just wondering, maybe you could do a trial run on the advance first
