Replace Sidelight On 2001 Rx300
To remove the headlamp you need to remove the bumper!!! PITA.....*
As above easiest to get at it trhough the wheel arch access.......still a PITA, but not quite as painful.
* Well actually you can just release the bumper and drop it forward slightly, but still the same procedure as removing completely.
haven't owned a series I for a while so I may not remember correctly but isn't it documented in the owners manual?
No.............
Headlight bulbs, side mounted indicator bulbs, all rear lamp cluster bulbs and even the license plate bulbs.........but funnily enough the embarressingly difficult (due to bad design) front side light (parking) bulbs are omitted from the procedures, how odd! :whistling:
:D
