Gs300 Mk3 06 Plate Trans Issue Shift Solenoid
Hi all
I have added to my lexus collection an absolutely lovely 06 plate Gs300 SE to go alongside my ls430 and is300
Slight problem is that I keep getting an ob731 (shift solenoid) fault that stops the car shifting up gear
If I reset the ecu by disconnecting the neg terminal on the Battery the trans will shift fine but then will throw the fault after a while and I am doing 50 mph with 4k revs
My local garage have changed the fluid in the trans but 2 questions, where can I buy new shift solenoids and does anyone have a diagram of the solenoid numbers ie what is solenoid 3 for example
If anyone can help that would be great
Col
http://www.clublexus.com/forums/gs-third-generation-153/
Hi
Have you tried the US site they have loads of answers to problems like yours the 4 Shift solonoids are in the valve body and what ive heard its usually SL3 thats at fault
You can get these parts from the US
Anyway hope it helps
Robert
