I own a Lexus IS220d from 2009 and i'm not being able to play mp3 discs on it.
The unit is not reading the disc. Do i have to burn the disc at a certain speed?
Are they any models that don't play mp3disc?
Also i read on the forum that some of you are able to play DVD's as well. I tried to put a dvd in the unit but nothing happen (tha car was not in the move - just parked).
Thank you for your help.
Re:
I've managed to make it read mp3 cd' - I just used a diffrent software to burn the music - I used ashampoo burning studio.
I cannot make it play dvd's pr audio dvd's. Could this be because my unit doesn't read DVD's? If it doesn't read can I still make it read audio dvd's as i read in one post here, using a certain software?
Er, I don't have the nav unit - And use CDBurnerXP for all burning needs.
So no idea about the DVD's
One thing, Car CD players are not as good as PC ones, I always burn CD's for the car (MP3 or audio) at a much lower speed than full.
On the Ford Focus it needed to be burned at 4x or it would skip...
This one seems to be better and can burn at 16x or over (not tried faster).
Basically the slower you burn the CD the more accurate it is. (Actually 1~2x speed is actually more inaccurate but for simplicity's sake, not at max)
It only takes a few mins per CD anyway :)
  • 4 weeks later...
