Clock On Permanently
:shutit:
Dear all
Would like to start up with thanks .I manage to put in my reverse sensors from another post .
I just install a after market double din HU.#But my clock stays on
Its driving me crazy not to mention it attracts attention at night (with the clock back light)
I have remove the stereo and still the same. Any ideas
Stereo comes on when the car ign is on
Thanks all
you have something wrong with the wiring of the new double din. i had this problem 1 night when eveything stayed on once i had turned my key to off and took it out. turned out to be a wire that had come out and touched another bit which kept the power there.
Figure it out its a poorly design amp by pass from AUTOLEADS PC2-92-4
The lead joins 2 yellow wires together
1 is contant
1 is ign power
You need to cut ign power and join to the HU power lead to it
and boom you done it
If you just plug in the PC2-92-4
You will not get any power to the HU
If you run a seperate power to the HU and leave these 2 wires togther your clock light stays on
message me if you stuck
Had the exact same prob with the autoloeads by-pass cable, one of the batch's must have been faulty, i had to cut the 2 yellow wires & join one to the ignition feed, sorry i never picked up on this thread or i could have assisted, sorry bud.
  • 2 months later...
  • 3 years later...
  • 8 months later...
