Negative Camber On Front Wheels?
Yes Ray unfortunatly this is very common.
It's a long story and there are many threads on this but basically Lexus geometry/camber set up is rubbish. It causes front wheel inner tyre wear as your pics show. I questioned Lexus Bristol about this...they say the set up is for comfort, fuel economy, handling etc and you "shouldn't" see significant inner tyre wear but we all do! basically a load of BS!
A company called Wheels In Motion took up the challenge of setting the car up to avoid inner tyre wear that Lexus are pretty much saying is unavoidable. They were very succesful and a lot of members, myself included have had their car geometry set up done there. it's worth the trip to see them however far away you live as they will cure this inner tyre wear 100% and your car will feel tighter and more responsive and just as smooth and comfortable. Mine felt like a different car honestly.
yeap it is common with the factory settings and standatd suspension
Also check the tyre pressures, I was told by the Lexus dealer to inflate them a bit more 1-2PSIs to keep them better...
I would also say go to WIM and have the car alligned all around
Cheers guys,
Just Googled WIM and it's a 5.5 - 6 hour round trip (equals 2 new tyres and 90 quid in fuel) :whistling:
How long does it take to set this up as I'm driving down that way to catch a ferry to Holland later this summer?
