Lexus Rx 450 - 59 Plate
I got into the car this evening, and twice pressed the Power Button , but the Ready light didn't come on ,all the other Dash Lights came on as normal. The car wouldn't do anything , so got out , locked it then unlocked and tried again , but still the same . Tried once more inside the car but still no Ready Light.
Got out and locked it again , and left it about thirty seconds before trying again. Luckily this time everything worked alowing me to drive home .
Anyone ideas ?
Thanks Rob
I had this problem on a Jag, it was caused by a problem with the immobiliser chip in the key. I found the cause by starting the car with my wife's key, and then started the car with my key but inserting it upside-down.
Would be worth a try with another key if the problem occurs again.
Everything has worked as it should do today for the Missus . Hopefully if it plays up again , it will be before the one year warranty runs out early next yet . Going to ring Lexus tomorrow to tell them what happened so they can put it on record.
