Steering Wheel Height Adjustment Not Working.
hi
first and foremost i would remove the steering cowl and give a dose of lubricant to see if it makes a difference.
the tilt motor is easier to change than the telescopic motor
have a read here:
http://www.clublexus.com/forums/ls-3rd-gen-2001-2006/674677-2005-ls430-tilt-motor-replacement.html
Reach adjustment is working, height adjustment isn't. Can anyone tell me what parts are required to fix this and advise on rough cost? Is there anywhere cheap to source parts and get an indy to do it?
Don't you need to look at the problem before you start ordering parts and worrying about the cost?
