Reverse Light
would this LED light still give enough rear illumination
http://www.ebay.co.uk/itm/281872491738?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
i have tried led's for reverse lights before on another car and they didn't provide enough light to the rear of the car
with these having a projector lens would this help at all.
any advice would be great
would this led light still give enough rear illumination
Not powerful enough as it is described as a W5W which is for side lights. You need a W16W type.
I fitted one of these and it is pretty bright compared to the weedy little filament bulb it replaced. It also has a COB LED which are brighter than standard apparently.
http://www.ebay.co.uk/itm/291324868533?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Hope this helps.
Ed :flowers:
it is easy
open your boot lid and look at the lining you will see heads of the clips holding the lining in place
i think there maybe 10 in total, you now need to remove the panel clips ,i use my panel removal tools
the same as these http://www.ebay.co.uk/itm/4pcs-Car-Door-Plastic-Trim-Panel-Dash-Installation-Removal-Pry-Tool-Kit-/172067722663?hash=item28100915a7:g:GTEAAOSwLnlWmiFT
hook the fork shape under the head and gently lever the clip out
you can see the fork being used on a white clip in one picture
the bulb holder comes out like any other rotate it and pull.
how hard is it to replace the reversing light bulbs? Thanks
Only one bulb required!! Why Lexus feel it is acceptable to only fit one reversing light and one fog light is beyond me. Even a Dacia Duster has two of each!! :megaangry:
here is a picture showing the trim removal tool being used
within 60 seconds you can have access to the bulb
i have now changed the bulb for an LED either tonight
or in the morning i will see how good it is / isn't
below are the specifications
  • New generic Super Bright Cree High Power LED bulbs For Backup Reverse Lights T15 Day White
  • Features:
  • Power: DC 12V 5W
  • Lumen: 950
  • Light Color: White
  • High quality, brand new, never used
  • Applications: backup reverse lights.
  • Lamp emmits a stronger & cool color & brighter Lighting than the stock bulb.
The one I fitted is definitely brighter than the filament bulb it replaced.   Maybe 5w isnt powerful enough? I fiited a 7.5w and some were 20 and some 50W!!
Ed
