wheel centre caps
Hi Guys,
Have literally only just joined the LOC so  I have no idea whether I'm in the right place or not!
I have a 2004 IS200 with 17"wheels and would like a set of decent wheel centre caps; If I've measured correctly mine are 63mm,
does anyone have a set or advice on the best place to get them?
Thanks a lot,
Chrissie
Quote
Hi there, they measure 64mm edge to edge, 54mm inside ring to ring and 58mm outer clip to outer clip! markings on the inside are 2708, 2710, U46 ,>PC and ABS>
WOULD REALLY APPRECIATE THE HELP,THANKS
64mm probably closer than 63 although it's such a tiny difference, my current ones are black with silver logo and rim on 17"  11 spoke wheels, have had a good look through e bay and amazon but can't find the exact right size 😐
Thanks for your help, yes I saw these but unfortunately they are quoted as being 62mm, no returns, I will continue to keep an eye out but am thinking it may be possible to re-furb the ones I have; at least I know they'll be the right size ☺
