Hi, The low tyre warning light came on today, checked all tyres all have the correct pressure, Pressed the reset button below the steering column still the stayed on. Does this mean a visit to the local Lexus dealer, or can someone help Cheers
I guess this feature isn't on my Mk3  ?  ........................ too much technology to worry about methinks
Thought TPMS was only on much later vehicles, and compulsory from 2014 ?
I read that corrosion of cap and valve can cause problems.
A lot of folk fit plastic caps to avoid the issue...I don’t know if this requires disconnecting the sensor system.
Not sure what model you have but iirc its press and hold until light goes out - I have 04 ls430
Thanks Mark did the trick at the 3rd try I have 04 430
