Changing Brake Fluid using Techstream
Hi all,
Car has hit 100k miles and I'm going to do a service along with changing the coolant and brake fluids.
From what I understand I have to activate the ABS pump using techstream to change the brake fluid.
Has anyone done this, if so is it an easy task?
Also is there any other fluids/parts I should look at changing at this mileage?
Cheers.
