Rear Parking sensors no longer Engaging
Superjim82
Morning All,
Recently, Rear parking senors have not be engaging when car is in reverse? Camera works fine, and car is under warranty, just wondering if anyone has had a similar occurrence? My initial thoughts were dirt possibly in the or around the sensors from the usual winter muck on the roads?
TIA
As above, would check and see if your reversing sensors have been turned off,on the IS250 you have a menu that let's you turn them off and a lights on your dashboard indicating they are off,not sure if the same applies to the CT200
