RX450H Electric Heated Seat Swap
Hi. Just purchased 2010 Rx450H with creme interior. Front seats are very worn and torn. Have found a good set from 2012 model for sale. Does anyone Know if they will Plug and Play. All functions Electric. Heating . Memory and Airbags or will they need to be coded to the Car Ecu/Computer ???? THANKS IN ADVANCE
I don't know but if you've already bought them just bung them in and see if things work - they either will or they won't. At least they'll be nicer to sit on than your existing ones.
If they don't, you may be able to do it yourself using Techstream.
Yes, should work no problem. I fitted some from a 2014 into my 2010, only difference was the seat belt buckles, simply swapped them over.
All electrics and memory seats worked fine.
2 hours ago, ColinBarber said:
They should just work - they don't need to be coded. You only run into problems where you are putting in a seat with different functionality to what you currently have (e.g. no-memory vs memory seats).
The only difference is current seats have forced ventilation & the Seats I have found have heat only, have not bought them yet, wanted to find out about possible coding, thanks for your help. Colin
Great Help, Thanks, The only difference is current seats have forced ventilation & the Seats I have found have heat only, have not bought them yet, wanted to find out about possible coding, thanks again for your help. Colin
