2007 IS250 Brakes squeeking on braking and also when reversing
louisp
Hi Guys,
I recently bought a 2007 IS250. 73k miles. All good but after hitting the brakes 5 or 10 times the front drivers side starts for squeek (high pitched). Then when I reverse it makes an odd lower pitched longer squeek.
I took it to the garage and they did the following to check if all OK;
- Removed, cleaned and refaced the front brake pads
- Checked the brake caliper
- Cleaned out carrier and lubricated the sliders
- Checked rear pads and discs for wear and tear
Everything was OK, but they still squeek!
Anyone know what the issue maybe? It's a great car, but the squeeking is ruining the driving experience, especially with the windows open in summer 🙂
Many thanks
Check the anti squeal pads are in place, the metal piece between the pad and the caliper and that it has copper grease on it.
3 hours ago, Lageoddvin said:
The squeking is only when braking, or constantly?
It's only when breaking except when reversing, when reversing it's squeeks without the brake.
Thanks, will check that out
  • 4 weeks later...
Does that wheel get especially hot after being driven, compare to passenger side, if so it suggests binding.
I presume discs aren't excessively lipped, has the condition of the flexible brake hose been assessed?
