Wash and Polish
2 hours ago, westo3 said:
Nice result. Did you correct the paint work or just use polish before the ceramic coat?
I already corrected it when I bought it as the dealer had done a terrible job as there were holograms and trails all over it.
Just needed a polish this time.
Polished then used a polish remover before the ceramic. I did my wifes new car straight from the garage with the same stuff and it is realy good, water just sheets off.
Like Herbie I am curious to know what polish remover you use and why.? Are you talking about a control cleaner to remove polish residues? I tend  to put the polish on after the ceramic coating
Having re-read my post, what I should have said was that I wax after the ceramic coat having used polish to to get the paint work ready for the ceramic coat and yes I do use a control cleaner to clean off the residues before the ceramic coat and then apply about two coats of wax.
I used Chemical Guys wipe out surface cleansing spray to clean the paint after I used the machine polish which was Meguires 205. Then I applied the ceramic coat.
Raining this morning and the water is running off nicely.
√ó
√ó
