Best way to bluetooth music to the sound system on RX 400h (2007)
12 minutes ago, Lee Riley said:
Yeah I need a full new cable. Your replies did inspire me to open up the cable though and try to solder it. I found two broken wires and did a bodge soldering job. Worked! but only on one channel and was really flimsy
Well it's already broke so you can only improve it from here :thumbsup: Give it another try and just take your time with it. Put some flux and solder on both the wire and the pin, then use tweezers to hold the wire on the pin while you get the soldering iron on it.
