Hi I'm sorry if I'm posting in wrong place please let me know if I am
I have a lexus rx 300 2005 just had timing belt done and spark plugs new ocv sensor. Running a bit lumpy now and smoking these are my fuel trims can anyone help this is at idle Screenshot_20220523-052344_Torque.thumb.jpg.51594a6bb32d36bb2bf2ea4cf3db22d5.jpg
On 5/27/2022 at 11:23 AM, Haylands said:
LTFT want to be in the range -10% to +10% and preferably as close to 0 as possible.....
I changed injector seals, inlet manifold gasket seems to get worse as engine gets hot
Check all the hoses for the inlet are fitted correctly and not leaking... If you can't find anything obvious then I think you better take it back and ask them to check the timing, If they put the new belt on one tooth out then that could cause your issue....
