isf front disc offet measure
hello everybody!
i'm writing from italy! i'm not an isf owner but i need your help for a project! hope you will help an other car enthusiast!
i want to fit the isf fron brake (360x30) disc to an other car and i have clearance issue. i'm trying to figure the offset between the external surface of the disc and the surface at the hub, to understand the distance between the two and see if the calliper will touch the wheel!!
if i know this distance will save me lots of money! i can't affort to buy the disc just to take this measure!!
hope somebody of this group can help me!
thanks in advance!
1 hour ago, Texas said:
So… is he looking at 60.7-30-6.3 ( =24.4 )as the critical measurement?
hard to say, i would have thought he would need to factor in the 6.3 too as that is further offsetting the wheel
Exactly!!! That looks like even Better offset of the. 330mm disc i'm running witch Is less than a mm away from the wheel spoke... Not safe at all.
So looks really as an option...look forward to try
Just out of interest, what are you looking to run the ISF discs on?  What calliper are you using?
