Radio Code
Ancient Dave
No, but you will probably need to reset the windows, sunroof if it has one, and the radio presets.
To avoid this, just connect another 12V source to the cables immediately before releasing the Battery clamps.
1 hour ago, Ancient Dave said:
Thanks for the help Herbie hopefully i know how to reset every thing
For the windows the auto function may not work. Single press the button and hold until the windows fully opens + continue to hold for another 3 seconds, then do the same when closing. That calibrates the system which allows the auto function to work. Repeat for each window that has auto function.
It's essentially the same procedure for the sunroof.
