Tail lift not working, double beep, not opening NX300h 2015
On 9/18/2022 at 9:54 PM, ColinBarber said:
If you manually open and then close it should reinitialise the system and then work.
Hi Colin, thanks for response. Unfortunately that didn't work, but service called me back today & said there is an on/off toggle via the buttons on right hand side of steering wheel. I found it & it worked! All the best, Alex 🙂
