It's a 2008 - gotta be halogen. (Unless the whole headlight has been replaced and other mods made - any other bulb (LED or gas discharge will fail MoT))
There are several bulbs in the headlight:
Main beam: HB3
Dip beam: H11
Parking light: W5W
Turn indicator: WY21W (You need to remove the headlight to change this - the others are relatively easy)
Easy DiY except the indicator - I'd recommend you change both sides to ensure the light output is matched. And anyway, the other side will probably fail soon if you don't change it.
You do need to remove a bit of stuff - eg the air filter housing on the right and move the washer inlet tube on the left.
Not necessarily, SEL came with Xenon - the way to tell is whenever car has headlight washers or not. Xenon has them, halogen does not.
