Plastic fittings for trim clips to fit in to
Hi does anyone know the name or part number for the white fittings that are fitted into metal holes for trim clips to be pressed into.
There are so many different types that we will need a photo of one to be able to advise.
There will probably be at least 20 different ones on the LS430, let alone across the Toyota range.
I normally search on eBay and then compare the pics to what I have and then buy some that look the same.
Sometimes I end up with the wrong ones, but not often.
